Hello,
I recently fitted vinyl flooring which is all fitted and looking great, but what I'm looking for is some floor edging strip to go over the vinyl and down the front of the board at the side and rear door thresholds, anybody got any ideas where to get this I've looked in local carpet/flooring shops but with no joy
I used a PVC Angle section I got from a local builders/timber merchant.
Section is 25mm each side, so had to saw the vertical section down to the thickness of the floor leaving the horizontal section 25mm which looks about right. Stuck on with Sikaflex.
Has a code number ER045B8
Have you got a pic please
