hi all i am changing my clutch does anybody know if the general advice is to change the flywheel mine doesnt look to bad ...
thanks all:ILU:
Meithered to death
Yes it has a solid flywheel,if the surface where the friction plate is sound with no fractures or scorching then it will be fine to use again.
thank you i will check it over again 2moro it had a few black marks of the clutch plate but looked in good nik so hopefully then can save some money there to spend on something else
thanks again
:D
been in garage all day checked the flywheel and there is no fracturing or severe marking on it so i think i shall be using the same one priced a new one and they arw exspensive.........:ILU:
