So decided to see if I could improve the hot air venting situation from behind the Waeco CR50 fridge we have fitted in our self build camper.
Its been on my list of "things to do" for the last few years, so eventually got around to doing it. It was supposed to only be a case of adding a vent to the blank furniture panel mounted above the fridge....however things soon developed into something else.I:
As you will see from the photos below, I had a friend of mine make me up a custom fridge vent (can put anybody in touch with him for any kind of grill required) for me out of 3mm pin seal ABS. Super glued some fine midge/mossy mesh from Ebay on the rear of it along with a couple of lengths of 5mm square steel bar, also from Ebay (more on that later). And finally added one of our Vans "FootPaw" logos to finish it off.
Took the fridge out so I could take the furniture board that was mounted above it out to cut the required sized hole with my trust jig saw. Painted the cut edge in some matt black paint I had lying around and mounted some small rare earth magnets (also from Ebay) to the edge of the hole in the furniture board which then gives me a "stealth" look no fixings i.e. screws method of holding the vent in place via the power of magnetism to the steel bars (which also add some rigidness to the vent).
But it was whilst I had the fridge out and looking at the fan that was already affixed to the rear of the fridge to draw air through the heat exchanger that I thought, emmmm I could assist the movement of hot air from the rear of the fridge out via my nice newly fitted vent via the addition of a extra fan or two.
So having a quick rummage through my various boxes of Computer bits and bobs I came across a brand new Dust proof 92mm AcoustiFan which is a very quiet PC fan (used in media centric PC's). I quickly realised that 92mm is also the same size fan as the one that was fitted to the rear of the Waeco CR50 as well.
A quick measurement of the available space in the void above where the fridge sits and I determined I could fit in a couple of 92mm fans to aid with air flow. I then decided to replace the fan already fitted to the CR50 with my original AcoustiFan and obtain a couple more form Ebay (£10 each).
At the same time as ordering the fans I also ordered a couple of 500mm lengths of aluminium angle so I could create a frame to mount the two extra fans into when the arrived.
Then knocked up my frame held together with rivets, painted it black (so it cant be seen through the vent), mounted the PC fans to it using some silicone anti-vibration mounts, the whole thing was mounted to a piece of MDF which was screwed to the furniture just above where the fridge sits.
Sorted he electrics out so the extra fans are stepped to down run at 5V DC for minimum speed but maximum silence, but still draw air though (the speed reducing cables/resistors come with the fans). They are connected in parallel with the fan fitted at the rear of the Fridge as they only draw an extra 350mA each when running.
