How do you remove the front badge off a '55 T5. Any pics or advice would be welcome. I want to replace the badge with a new or second hand one,
If it the same as a 5.1 you twist it anti clockwise, it feels like it wont move but it does. refitting is push it in and turn clockwise.T:
It has little clips that will need to be pushed out by getting to the back of the grill and using a small screwdriver to pry open the grabbing bit, I took mine off yesterday but already had the grill removed from the van.
Thanks for info, I have tried twisting, to no avail, will wait for the warmer weather to remove grille in case the clips crack on removal. Then prise the badge off as suggested,
