Hi all,
I've an 04 T5 Kombi, 2.5 T32 and am going to replace the front bumper from the grey plastic one to a newer, colour coded one from a Caravelle/mulitvan. The one i've purchased is 2nd hand and comes with front parking sensors, my current bumper doesn't have them.
My question is, as my van has rear parking sensors, can I plug the front into the same wiring loom and if so do you think the connection will be there or should I be looking into buying a section of loom to connect the 2 together?
Or indeed does it need/work on a separate loom/warning siren?
Cheers for any input.
Special Rapporteur
The general rule with VW (in recent years, at least) is that if the option was not ordered from the factory, the loom will not be there. If you work on that basis, you might be lucky and find it there (but all of my experience on T5s suggests that it won't be).
If there are spare ports on the control module (there may or may not be - I don't know), it may need coding before it will handle extra sensors.
