Hello bus fanatics, looking for a bit of information. I have noticed there is some play coming into my front door hinges at the pins. The doors are only held on with bolts by the looks of things. My questions are as follows;
1, Are the doors only held on with bolts and is it a straight off and on , or is there some adjustment in the mounting plates when the bolts are loose.
2, Can the hinge pins be replaced with new ones or is it a case of replacing the full hinge.
3, If the hinge pins can be replaced do they just knock out or is there a special tool also do they come out from the top to bottom or vice versa.
Any help gratefully received, cheers.
