I've sound proofed/insulated most of my T5 and was going to attempt fitting sound deadening material to the front doors as well and wanted to know if the door panels are easy to remove?
Also are the door skins still sealed with a plastic membrane?...........I remember getting leaks on my Mk1 Golf after I tampered with them years ago:(
Same with the wheel arches, I've read posts about deadening the wheel arches under the van; how easy is it to remove the arch liners?
Guidance appreciated
Discussion Starter #2
Now sound deadened the front wheel arches & cab floor on the inside which was probably the easiest area to do so far, but any info on the other 2 areas above appreciated!
