Hi All,
I have just picked up a VW T4. It has fog lights on the front but the wiring job is diabolical and I want to rewire them to look a bit more professional.
I'd like to use a double pull type headlamp switch but so far haven't been able to locate one that matches the type I have.
Does anyone know if they exist and if so, where I might get one.
Cheers for any help you can give.
Chris
what age van have you got?
fitting newer rotary switch to an older model will take skilful fettling; its not a straight swap I'm told
lots of threads here about the premade T4sRus fog lamp loom that just plugs into the back of your fuse box
add a relay to the panel and off you go
the 2 posn rocker switch is prewired
if it's light you're after then the headlamp loom upgrade is 100% recommended
If its a late t4 with the rotary switch then get one from a mk3 golf with front fogs, the illumination is green but it will work. Mines from a mk3 vr6.
Hi
Thanks for the info.
It's a rotary switch that I have.
If the MK3 Golf switch will fit I'll try that.
I have thought about the head lamp loom upgrade. Its on my to do list!
