Just had mot failed on brake hoses had them replaced since then the front n/s been binding on after abit of a drive had it checked and the brake pad was wearing uneven had the edge skimmed off so it wasn't catching as there was a few thousand miles left on rest on drive home same happened so just had new pads and disks fitted great no same happened again any ideas ? I:
hi mate
when the hoses were replaced it might be that the hose has been
twisted causing a pinch inside.
was the brake fluid bled out of the caliper or just pressed back into the system
as this can drag up crud and cause issues too.
mike
Not sure if fluid was drained out I know he replaced the small bits of copper pipe going to the calliper as when I went back the first time it had a kink in it so he re done it will be on to garage again tommorow thanks for reply
