My N/S front tyre is wearing down fast on the outer edge , I replaced the front tyres about a month ago because the thread was almost showing and it's started to wear down again . I know I need to take it for geometry check , but was just wondering if anyone knows what's its most like to be , with it being the outer edge is it more like to be a damaged or worn suspension part rather than adjusting the toe ?
The front tyres on the outer edge always wear quicker it's just the way it is, you can improve it a bit by getting a decent alignment is your van lowered??
If your suspension is worn then that will contribute to poor tyre wear too. I'd get the whole lot checked out.
Is it lowered, standard wheels? You really need to get your alignment checked pal but like already said I would get it in the air first and check for worn joins etc
As has already been said tracking wears tyres but check the lower arm bushes and ball joints first as these wear out causing the tracking to move out of spec.
Theres no point tracking a van with worn joints etc
