I have needed a wheel bearing replaced since last summer.
I have been given a puller kit for doing this job but their is a fault with it.
One of the half circle parts is not machined to match the other side.
I believe this is a common fault on these cheap pullers.
Can I use this or do I have to get it sorted as this is hardened its gonna take a lot of machining.
SC
I had the same situation with a cheap tool from ebay. But to be fair, they sent another part pronto and it did the rear bearings well. Fronts look like more work as driveshafts need removing.
