I have problem. During night fuel filter become empty, and in the morning i cant start ny car. I allready canged filter and plastic on the top of filter, but this morning problem was same. Is it possible that some fuel line is demaged and air comes in that fuel leaks back to fuel tank? There is no signs of leakage from outside!
It will be air getting in at the small black leak off pipes on your injectors, causing the fuel to run back.
You can replace the small rubber pipes or also put a one way valve in your fuel line it will have the same effect and stop it running back to the tank.
Also welcome to the forum.T:
