1 - 9 of 9 Posts
i have a 57 plate T5 with a flappy fuel flap, seems the spring has gone missing before i bought the van. not a big issue as the door keeps it shut but it does look a little untidy when it's not quite in place. any suggestions where i can get replacement springs ?
Give TPS a try buddy, they're normally worth a shot with things like that. Also try adjusting the black rubber screw with a flat headed screwdriver to get it sitting properly :)
It may still be there. I had this problem took it off to look at it and found the spring thing still there. It doesn't look like a spring as such more like a piece of bent metal.
7H0 809932 50p each I believe. Also available is the little plastic retainer that sticks out 7H0809948 £1.00
Look like this
Hi I'm also missing one of those but can't find anywhere that sells them in uk on the web....where can I get one from?
1 - 9 of 9 Posts
