If you look at this site you'll have an idea what i need http://www.eastment.net/Boschpump4.htm
I need the two springs and a retainer, garage says this is all i need to get the van back on the road.
Its a fuel pump off an AAZ engine that i need the parts for, does anyone know where to start looking or have a AAZ fuel pump i can use or strip for the parts ?
Cheers :tu
This is the big problem i have buddy, there are no part numbers i can find, nothing on Etka either :blg
hi bud,has the pump been removed from the engine? if so,then drop it off at a good injection specialist,they may keep these parts in stock if this is a common problem.it may also be a good idea to have the pump overhauled at the same time,may save you another job in the future.hope this helps,joeT:
