This is my first posting - so hope it comes out okay
1997 1.9 TDI T4
When I turn ignition on (i.e. not turning key all the way ) there is a constant clicking sound from the fuse box, lights iluminate on the dashboard and the speedo goes up and down. When I turn the key all the way nothing happens (but clicking stops temporarily - sometimes there is a buzzing when key turned back)
I have traced the clicking to a relay marked 104 on the fuse panel - which I have discovered is the Fuel Pump relay
I can source a new relay but they cost £40. I've taken it out and and it looks okay.
The van was in the bodyshop for a respray and park sensors fitted last week. It worked for a couple of days after I picked it up. I was warned that the battery was low. Stupidly on Saturday I worked in the van for a couple of hours with the stereo on, but I don't think the problem is a flat battery.
I've tried using booster cables and a battery booster - didn't help
I've also disconnected the battery overnight but this didn't help.
I'm about to spend £40 on the new relay but wanted to check if anyone has had this problem/can think of anything else to try before I part with my hard-earned
Thanks in advance
P3rky
1997 1.9 TDI T4
Thanks in advance
P3rky
