Hello everyone
Broke down last nite, the T4 2.4D i have just cut out :(
It apears it was the fule pump relay , i had no 12v supply to the fuel pump solenoid.
I put a temp 12v supply from the battery 20amp fuse to get me home.
It appears that the fuel pump relay is faulty
is this a common problem ? and are they main dealer only item ?
i might put a temp realy in the engine bay controlling the 12v supply from the battery until i get one. :D
cheers
Discussion Starter · #2 ·
UPDATE
Been to VW Commericals this morning.
The AAB Doesn't have a relay controlling the fuel solenoid on the pump , its the factory fitted immobilizer that controls the 12v to the pump.
so need to bypass the immobolizer.
Job done
i have fed the pump solenoid direct from a 12v relay controlled by the ignition T:
running like a dream now, also fitted new fuel filter after the old one was contaminated by some dirty cooking oil.
see you all at VW Action :ILU:
