I'm new to this forum, but need some help with my T4 1.9TD. I have just replaced a number of parts, including the engine, but the new engine won't start (it was working before installation). I have rebuilt lots of different cars (but need simple explanations!) so I'm confident it's mechanically correct, but the issue seems to be electrical.
On the old engine the fuel pump only had one purple wire going to the nut above the injector pipes. The new engine has the black box on top of the fuel pump and cylindrical solenoid at the side. The old fuel pump did not have these.
All the wires were in place in the old engine to connect these up, so I have connected them all using the original wiring loom where they had been cut/disconnected before. However, I get no clicks from the relays, no Glowplug light on the dashboard and no starter motor.
Not sure if it is relevant, but the wiring loom also has a home made bridge in the loom connected a red and a blue wire (though not near the fuel pump).
The engine is from a 1990-1996 vehicle, but mine is a 2000 year.
Any help would be much appreciated as the van is off for it's MoT on Friday.....
Thanks in advance!
Thanks in advance!
