Hi. I'm fitting a diesel heater to my T5 2.5 AXD. I've dropped the tank, removed and replaced the sender unit, disconnected the lines and refitted. I've also changed the fuel filter. Now I can't start the vehicle...
I've tried turning the key to prime the filter many times, and turned over for a long time. I've put 10 litres of diesel back in the tank. It is up on ramps under the rear wheels, so on an incline, but I'd have thought it would have enough fuel.
I'm wondering if there's an airlock in the fuel line. I've tried disconnecting the blue line from the tank (marked VF) at the filter, and putting the open pipe in a bottle. When I turn the key I don't get fuel, which I expect I should? Any thoughts on how I can troubleshoot this would be appreciated... Thanks.
