I've just bought a VCDS lead and run measure blocks to see if there was any dodgy readings. I noticed that the fuel temp sensor was reading 111 degrees C.
I hadn't driven the van for an hour, and it's about 5 degrees out. So I guess the temp sender is on the way out. My van may have been remapped. Could this affect the reading?
Does anyone know where the sensor is and how much a replacement is? Thanks
The sensor is down by the tandem pump on the 1.9 engine and has a 2wire connector on it. Just check the wires because the snap in the loom like mine has and this will throw up faulty readings.
Special Rapporteur
Has it been remapped or chipped? The latter will often mess with sensor inputs to trick the ECU into changing the fuelling level (though I admit I don't recall ~fuel~ temp being a common one to modify).
I think it has been remapped, I doubt the fuel temp was part of the mod, however I just wanted to ask the opinion of others. Having remapped my t4 my self using VAGsuite and MPPS, I know that the usual maps that are modified are the smoke maps, torque limiter and boost maps. I just wanted to dismiss the fuel temp reading being effected the map.
I'll have a look at the fuel temp sensor later. Does anyone know the resistance values for a given temp?
Ok, for those who are interested. I bought a new sensor, on fitting the sensor there was a little box sitting between the old sensor and the connector. Must be one of those cheapo tuning boxes. So the van hasn't been remapped. Glad I found it though. Right, I've just pulled the map of the ecu, lets see if I can remap it. I managed to do it on the T4!
