just collected my van for the first time in 5 or 6 weeks and on the way home i noticed that if i swtiched on the full beam lights it actually turned the lights off entirely. now the van has been in for work ( injector pump and starter motor) and im wondering if its going to be something as simple as a fuse, cant see now as its pitch dark outside.
the van is a 2.4 lwb panel van, the lights are standard bar the fitting of the upgrade kit, which worked perfectly prior to the van going in.
any ideas folks?
many thanks in advance
paul :D
Discussion Starter #2
couldn't settle, so headed out into the yard with a torch, found the issue, a wire had parted company with a connector, so a trip to the motor factors in the morning for some new connectors and that will be it resolved, bridged the connection there now to make sure that was it and lo and behold the lights worked :lol:
panic over
cheers
paul :D
