1 - 15 of 15 Posts
Over the last month or so my van has started to give out kind of a hot engine (diesel? Oil?) smell through the vents, particularly when the van comes to a halt after a run. It doesn't have to be a long run, just as soon as the van is up to temperature really.
I thought it may have been because I was due for an oil change (I do this every 5,000 miles) so I changed it and no difference...smell appears.
Van is a 98 1.9td and there's no obvious fluid leak in or around the engine.
Is there anything I can check? Pipe/ducting off or blocked? Has anyone experienced this before?
All help or advice greatly appreciated as it's doing my head in.
Do you definatey have the plastic cover for the pollen cabin filter...?
If not then it's just sucking in any fumes from the bay...
Somebody stop me!
+1 mines without at the moment and didn't do it when it had it. You will get some smells from around the engine bud, its quite normal T:T:T:
I'm aware that I should get some smells but it was getting near headache stage...and that aint right.
I'm gonna have an investigation on this tomorrow, so, anymore ideas?
Could possibly be an antifreeze smell
Is there any sign of a water leak? are you loosing any water from expansion tank?
got it on my work motor . 2.5tdi , and only when i stop , smells like rubber burning . so very interested in this one . i do have a small oil leak on top of engine by the oil filler and thought this may be it ?
the rubber leakoff pipes joining the injectors usually the cause of stinky diesel fumes,10min job,fiver to replaceT:
Discussion Starter · #12 ·
This is interesting, I've always had to top up my antifreeze ever so slightly about once a month but no real signs of a leak.
Discussion Starter · #13 ·
Smell located...one of my braided fuel pipes had split sending pretty much the entire contents of my tank (£65's worth of diesel) peshing all over the road.
Problem now solved for £2.54. Knickers.
Thanks Brumski , you solved my problem before I had even thought about it. took it off for a flat batt, did not put back on noticed it was smeling but did not put 2 and 2 together. T:
1 - 15 of 15 Posts
