I've got a t4 caravelle 2001 model. And I've a problem with the horn, so temporarily I'm going to take the horn fuse out until the problem is sorted.
I can't find the fuse box though. My booklet says there's one in the engine compartment, but it doesn't seem to say where it is?
Anybody know?
There are fuses in the engine bay, directly in front of the starter battery in a sealed black unit, it's fixed to the clamp that holds the battery in place.
Well...I'm pretty sure there is on my 2.5! :)
I think it's fuse 13...had trouble with my horn not working...turned out the wires to it were brittle and had cracked. alhough one broke the other broke the minute I grabbed it. Copper inside the wires was corroded and went quite a way back up the wire. It gets hit with all sorts of debris and water from the road I guess !
