Hi All,
Can you help?, my internal lights blew a fuse when I tried to change them for LEDs and my reversing sensors stopped working too. I have checked all the fuses in under the bonnet by the battery and all the fuses under the cup holder on the dash and the ones under the passenger seat, are there any anywhere else.
its a T5 4 motion, 2008, semi high top, ex ambulance in Australia.
HELP
The fuses for reversing sensors and interior lighting are under the cup holder, number 8 for reversing sensor and number 17 for interior lighting (I think). I would check them again and failing that try checking the fuse holder itself as they have been known to have loose connections on the back. There are further electrical connections and fuses I believe under the passenger seat, but these should not be effected by shorting out your interior lights.
I'm by no means an expert, but I hope this helps.
