hi all
i got a little problem on me van
2.5 tdi v reg 1999
vcds it today and it has come up with 17564 / p1156 manifold pressure sensor g71 - open short to ground(i think it said)
power data bus - missing message instruments 18058 p1650
also, the brake pad warning light is on (the sensor wires are twisted together on the rear and i cant find any wires on the front
the coolant level light is flashing (after about 30 secs it comes on) there is a beep as well
also the oil jug warning light starts to flash, think the beep sounds agaoin when this happens,
all at tickover
some time th eoil light doe snot come on but the coolant one always does,
whe i rev the engine the oil light comes on every time.
the rev counter sometimes does not work or is a bit erratic
i have doen soem searching on here but wondered if someone had the time to chuck in a few ideas
last thing,
i noticed a purple wire that has come out the back of the fuse box, its has a pin still attached so it looks like it has been pulled out of a plug (wether this is something to do wth my problems i am not sure.)
here is a pic of the wire and the lights that flash
thansk in advance
cheers
adie
2.5 tdi v reg 1999
all at tickover
last thing,
thansk in advance
cheers
adie
