Aarrgghhhhh!
Anybody know or recommend a good mechanic in the Reading area??
I need to get my gearbox looked at :(
Thanks...
HI sorry don't know no good mechanics but good to see someone from reading on here!! We just got our T4 so lots of work to do, any recomendations who we could use near by??
Good luck with the mech
Changed the N/S lower balljoint and the driveshaft dropped out of the diff. I thought it was back in solid enough but guess not as it lost drive afer a short trip. Towed it home, removed driveshaft and pulled out the flange shaft. The end of the flange shaft has snapped off and I can't see it or the snap clip. I assume they are floating around in the diff and need them removed before they mash up the whole gearbox.
Not sure if access to diff can be had from o/s, through the gear carrier or if the whole tranny needs dropping out and taken apart.
It's a 2.5tdi ajt engine, transmission code is ewb.
Up your street??
