Well after much waiting, and then . . . a bit more waiting the have turned up.
Just had a quick look and all seems ok, a few light marks here and there and a few damaged stickers on the shocks, which is slightly disapointing; but they wont be seen once fitted, so all in all the product itself looks very good.
These shall be going on my T32 camper, and Im planning on around a 60mm drop.
A quick questions for you guys that have them already.
- What is your prefered damper setting, as there seem to be 30 positions to choose from? I would like to have a ball park setting, from which I can fine tune to my likeing.
Cheers T:
I have my fronts set at around 12 clicks from softest, and rears at about 20 (I believe).. The other thing that I have done, is that on the fronts I put the factory damper protector (the concertina plastic thingy) inside the Gaz coilover spring.. It is a snug fit at the top, and I had to cut sround 3 corrugations off the bottom to make it fit in length.
I thought it best to keep all that road grime off my New Gaz damper...
Unfortunately I didn't take any piccies when I did it, but fell free to PM me if you don't understand, and I'll send you my Mobile number..
I changed these (on a new 5.1) with out the need to have new Drop-links etc... but... If youre van has done a few miles, these might be problematic..
The rears are a piece of cake, although you will need a file to remove the little nodules of 'weld' before the rear 'seat' will go on..
Good luck
Jules...
Thanks for the response Rossi, ill keep them settings in mind.
Also the gaitor idea is a good one I shall do something similar on mine. T:
Any One else got any prefrence to there ideal settings?
