I've had a recurring leak with the gear box filler plug on my T4 2.5tdi ACV.
Doesn't matter how tight I tighten it (as tight as two hands can) it still leaks, this will be the fourth time now!
Could the plug (with washer) be loosening itself as it's damaged? Can't see any visible problem...
Does anybody have the correct torque spec for the filler plug and know where to source a new plug online?
Recently had a new Sachs DMF kit fitted before a 10 day road trip and found the filler plug wasn't screwed down and only held on by a few threads
that might of done something... or over tightening. (Took it back to the garage and they topped up the oil and re-fitted the plug).
Any ideas or similar experience would be much appreciated...
Cheers!
Cheers!
