can the common ''sloppy'' gear change feeling be sorted by replacing the 3 bushes on the linkage?
thanks, adam. :ILU:
thanks, adam. :ILU:
Feels better, but will feel even better still if you buy rest of the bushes further up the linkage and do these at the same time. Can buy them all from brickwerks. Maybe think about short shift mod at the same time.
sound.
cheers for the reply, will get on with it asap as its the only thing letting my (first) new t4 down.
adam. T:
Just a heads up, if you do end up doing the short shift mod while your under there. Info I followed from here said to re drill hole 35mm from the original, I did it and that makes the movement super short, I'd prob do 25mm if I was doing it again.
cheers again mate.
