any of you gents know which gear oil i should be useing in a 55 plate T30 2.5tdi,havent got the user manual.....
got a slight clunck when engageing first,so thought i would drop the oil to see if it made any difference.......
thanks daz.......
Before pulling the box out make sure you check o/s driveshaft splines and stub shaft for wear (common fault) please report back with your findings as many have this problem
