Got a bit of a problem with the gear stick. Its a struggle to get it in 1st and 5th gear but when it is in gear there seems to be loads of play in it bit like it should be in neutral.
Any ideas what it could be?
Trigger
the rubber ball has degraded which sites on the end of the T bar, and sits in the clevis. this pushes down to select 1 and 2nd.
you need a new ball, not a lot of money, take the clevis off (bit the ball sits in, the two bolt heads you can see in pic) and it slots on the end of the T bar.
Cheers mate.
