Hi all, am putting a recon gearbox into my 1996 1.9 .I am gonna put a new clutch in at the same time, are there any issues or things I should be aware of? I'm pretty much a novice so any input would be helpful. The main thing is were is the fill point for the gearbox oil and what oil should I use? Many thanks.
The fill mark is best measured by sticking you little finger in the filler hole turn your finger at the first bend and when it dips in the oil it is full, filling until it runs out of the hole is overfilling.
The only oil you should use is VW gearbox oil from the dealers as it has it's own characteristics.
