Hello can anyone help I've put a new clutch in my 1.9 t4 and I can not get the box bk on I've had it all alined up but then it's like the cog will not slot into the clutch has anyone got any tips for me thanx
Wip the clutch back off and make sure the centre plate spline does actually fit on the shaft , might be the wrong part or just burrs on the spline,give the input shaft a clean up with a wire brush and apply a very slight smear of grease and then when you come to refit it turn the engine over using the front pully nut and see if it aligns then.T:
checked it is the right clutch it fits fine so i tried again and still had no luck ive droped the engine onto the floor so i will see if i can get it on that way im starting to think this van is never goner run again:(
Have you aligned the clutch plate needs to be perfectly in the middle of the flywheel and clutch cover?
