im not sure weather its me bieng paranoid or if its the van. it seems the gears are a a bit notchy.. its pretty new to me so im not sure if thats just how they are, but sometimes if i bang it into gear quickly it seems to give a slight crunch? not any gear spacificly tho? the van has recently had a new cluch fitted so could it just need an adjustment? im sure i have read somewhere that t5's suffer in the gearbox department? the van is a 55 plate with 100k on the clock but it does have a full vw service history i would like to think a gear bos would last longer than this?? any info or advice would be good.
as you said they are bad for boxes-clutch is hydraulic so no adjustment there,sounds maybe like gear cables/linkage,ask dazboi for advice-he could maybe point you in a direction of a common problem
