Hi All,
Does anyone know what gearbox I can upgrade to, my vehicle is a tuned T4 2.5TDI AJT currently sitting around 140-150 BHP, the old DUJ gearbox has been great but just does not have to top end, plus I grounded it out and cracked the casing so before i do a direct replacement is there another box I can bolt on??
You need to be getting an 02G box and you will have to change the driveshaft
Best code for your tuned motor would be EEZ GQF if you can find any of these as they were fitted to 150bhp vehicles if not you could go for the AFK or FJS
That’s great, will I need both drive shafts from the 150 bhp van?
Does anyone have part codes?
Thanks again. 👍
Sorry I can't help with part codes
Use both driveshafts and while you are at it I would look at putting the bigger clutch in which will probably mean changing the flywheel too which might mean changing the starter which might mean changing the...
It never ends...
