hi
is this common or is it just mine - seems a silly design fault, my gearstick rubs against the edge of my double front bench seat in 2nd gear its rally annoying anyway round it?
i have just solved this problem take gatter off undo bolt that holds top of stick on pull out the little pin that stops the stick from twisting round, now drill a hole 2.5 or 3 mm i think (check by using the hole the pin came out of as a guide) in the front 90 degree round stump of stick in line with the original hole. refit now the angle of the stick throws into the gap between seats. took me about 20 min to do and now i dont hit the leg of the person sat in middle seat its great. T:
