1 - 9 of 9 Posts
This was on my T5 when I purchased it.
It's a genuine VW model and can hold up to 4 bikes.
It works perfectly and has the attachments for the bikes. It has a slight bend on the top right which was there from the previous owner but it doesn't impact it's operation at all, just cosmetic, could probably be straightened quite easily as well :*
I've only used it twice since owning the van and is currently hanging up in the garage, so maybe time to sell it on.
SOLD
Hi can you tell me did you replace some of the end caps on the rails as black and red if so where did you get them from ?
I've not replaced any of the end caps but that's not to say the previous owner did :*
It's just as it was when it came with the van.
Cheers,
Si.
The top 2 rails look like they have been replaced as they are not genuine
Ahh, that may explain the red caps on those two rails. I'll have a look later and see if they have any details on.
Right, upon close inspection it looks like the previous owner has replaced the last two rails with Fiamma versions, this is where the red caps come from I guess as well:*
Bearing this in mind I'll drop it to £300 :eek:
Discussion Starter #8
Yep still here at the moment
1 - 9 of 9 Posts
