1 - 15 of 15 Posts
I have a W plate 1.9td T4 and am looking to get a bit more grunt out of it, it's too old to be remapped etc what would you guys suggest to be a viable but realistic option?
the turbo/fuel pump mod will make a difference
don't skimp on air & fuel filter quality (OEM is best ) or replacement intervals
check that accelerator cable moves freely (they can stick), and if a damper is fitted then disconnect it T:
enjoy
Turbo, fuel pump, injectors and taller fifth gear are about your only options.
I have the same engine and have removed the DPF from the exhaust and blanked the EGR. It's going to Maz at MV Engineering (Telford) for the rest early this year (I hope). I also use Diesel Rhino and regularly change my fuel and air filters, plus oil changes.
T4's never had a dpf, i'm guessing you mean the cat?
Maz is simply awesome. He is also my T4 mechanic, even though I live in Kent!!
He's just done £2500 work on our T3 Syncro. Its the T4s turn next.
Where in Telford is he based?
Andy:ILU:
Maz is on Halesfield....
https://www.facebook.com/pages/MV-engineering/229623683762014
Want to know what he can do?
Look at my thread, ALL the engine work was done at Mario's.
Performance speaks for itself.
Ive got an abl was horendous when i got it, ive blanked egr, adjusted pump and boost, 2.8 pajero intercooler, air filter and decat, goes well now
1 - 15 of 15 Posts
