1 - 15 of 15 Posts
:( so on Friday night I was on the motorway and the yellow oil can lift come on, I checked the dip stick and all was ok.
The next day I was driving to the garage to get it checked out n about three miles to go, I noticed a funny noise when changing gear especially as the revs got higher. When I got to the garage it sounded as though a tin can was being pulled along the road :(
Anyway I found out today that the dual mass flywheel needs replacing :(
Has anyone had this before or does anyone think that he oil light coming on might be separate problem?
I've only had the van 2 months n this has happened, I'm not a happy chicken at the moment :eek:
Super Moderator
DMF is in the gearbox which is taken off to be replaced.
Oil light might be just a sensor.
Get it plugged into vagcom to see if any fault codes come up.
DMF should cost around £700-£800 mark as a guide.
Good luckT:
My oil level light sometimes gives a false alarm & has done just after topping up the oil - lifting & closing the bonnet resets it.
Sometimes, these sensors need a "hard reset" - disconnect the battery for about half an hour (don't forget your radio code if any).
I doubt if the 2 are connected.
Discussion Starter · #13 ·
It was privately, I've done just over 1000 miles since I've had it. It was a mechanics van before so I thought it would have been ok.
Anyway it's fixed now so apart from a hole in my purse it's good to go :)
1 - 15 of 15 Posts
