1 - 16 of 16 Posts
Hey There
Can anyone who has one of these halford tools confirm that this is the right one please?
http://www.halfords.com/webapp/wcs/stores/servlet/HalfordsProductDetailsLiteView?storeId=10001&langId=-1&productId=214227&cm_sp=Intelligent_Offer-_-Product_Details_Zone_2-_-Blank&iozone=PDPz2&TB_iframe=true&TB_C_ID=productdetails&TB_C_TITLE=Laser%20Brake%20Caliper%20Rewind%20Tool&width=800
I want to buy the same one off of ebay for half the price but there's a left and right hand thread one so want to make sure that I'm going to get the correct one (right hand thread I think?).
g clamp is cheaper! I:
No idea if your link is for the correct tool, sorry.
Just looked on bennetts web site they are £16.12p now comes under laser vehicle service tools on there site.:)
Using a G clamp on the type that have a threaded handbrake adjuster inside the caliper and you will have screwed the caliper ! ! ! Expensive mistake ! ! !
The correct tool rotates the piston at the same time as pushing it home. I:
I know you have to turn it... otherwise my T5 would be ******, I should have clarified you also need to turn the piston whilst applying light pressure with the clamp.T:
Discussion Starter · #9 ·
Hey
Thanks for the replies everyone. It's for the rear brakes and after reading some of the posts on here of people struggling to rotate the piston, I decided it was easier to just buy the tool.
The tool on ebay (same laser one) is £14 including delivery whereas the bennets site are charging £7 delivery + £16 but thanks for pointing it out though.
This forum is better than a Haynes Manual!
on the fronts i used 2 large screwdrivers while in the vice with a block of wood and on the rears you can wind them back with some circlip pliars in the 2 grooves....
Well I have used a G clamp for years and never screwed a caliper yet!!!!!!! as long as its a right hand thread caliper and you put the rotating pad of the thread on the piston then it will turn the piston as ir pushes it back in
Banned
With the resivour cap of I used a g clamp one that u pump and it worked fine
1 - 16 of 16 Posts
