Hi folks, I’ve purchased some of the long trim clips from Harrison’s, to use on 6mm ply that has been carpeted with easy liner. Even with there extra length, they still seem too short and won’t remain in. I trolled them before carpetting the ply and they fitted fine. Has anyone else had this issue, and did you use a different clip?
many thanks!
I used fir tree clips for mine, ok they're hard to get out again if you need to but as there is nothing behind any of my panels I'd need to get to it didn't worry me
I’ve ended up using this system from Gallant- I was trying to use a width of ply and carpet that was far too thick for the Harrison’s clips (which remain very good quality). The screw system above is ideal for far thicker linings. I’ll get some pictures of mine online when I can.
That looks a good solution.
With fir tree clips I put mine into the panel then covered over with my covering, not carpet so they wouldn't be seen as they would have pulled it.
