Right here goes, i have been doing my t4 tdi conversion over a few months as a sideline and have hit many obstacles on my way but on Saturday I managed to get the van fired up and it was idling really smooth and sounded nice.
After reassembling the front end and popping some coolant I couldn't resist running her round the block to see how it felt to drive again.
At the bottom of my road the van suddenly started revving to 5000 rpm on its own and wouldn't turn off with the key, i had to stall in 5th to stop this and what I can only describe as a white cloud bellowed out my exhaust.
When I pushed it back home I found that the alternator belt had snapped and the inter cooler was red hot too touch, also I found oil around the manifold area that seems to be mixed with diesel.
I have since tried to turn it over and it seems lumpy so I stopped after a few seconds.
The set up is as follows
ABL - Turbo, Manifold, Oil Pick Up Pump, Power Steering Pump and Sump Pan
1Z - ECU, Immobiliser, Wiring Loom and Chip
AHU - Injection Pump, N75, MAF Sensor and Alternator
AFN - Remainder of Engine
I am wondering if I need to check or reset the static timing and replace alternator belt before I try and diagnose what happened.
Any help as to what this may be and what has caused this is greatly appreciated, thanks Dale
Also when I have done the wiring and reconnected everything I must have misplaced or missed something as now my interior lights, remote central locking (and central locking using the pin,) and electric windows no longer work and when I turn my ignition off my clock on the dash (for the time) goes off and when the ignition is turned back on it has reset to 00:00 now I imagine for the dash I must have used a switched live instead of permanent but the others I'm not sure.
Again any help is greatly appreciated on any of these matters thanks in advance Dale.
