1 - 20 of 22 Posts
having a clear out- updated
ok having a bit of a sort out, these are some bits left over from when i broke a van for spares a while ago
all parts are from the same "R"reg 2.5tdi multivan unless otherwise stated
please keep the inquiries to the bits listed- any other parts i have will be listed as and when i get time to sort them outT:
2.5 tdi ecu, earlier type with air pipe (built in map?) and bracket £40
cab headlining, light marks from storage and the cat has scratched the back slightly £25
hazard and heated window switch £5
cab step covers in grey, drivers and passengers £4 each
cab mat in grey (looks brown in the pic but is grey) £30
steering wheel-needs a good clean sold
sun visors sold
drivers door card- cracks on pocket £5
A pillar trims sold
headlining strip sold
o/s rear quarter trim upper and lower complete with speaker and power point (does not include the c pillar trim) £30
n/s rear quarter trim upper and lower complete with speaker (does not include the c pillar trim) £30
o/s rear light £5
gear stick cover sold
fuse box cover £3
ignition shroud (one screw hole damaged) £5
o/s rear window with vent- genuine volkswagen bolt in complete with nuts £35
n/s rear bonded window £35
n/s rear seatbelt- upper mounting bracket is included but has been cut and would need to be welded back together (quite easily done but as a safety related item is not recommended) £5
trim for rear headlining - goes across the width of the van by the tailgate/hatch £7
airflow meter good working order £25
3 std shocks in good order from my "51"plate ex aa (one rear had to be cut off as the upper bolt has seized, hence only 3) sold
pair of H/duty rear springs virtually new- bought new from gsf or eurocar parts cant remember which :confused: and were only on the van for about 3-4 months before deciding to get a full KW kit £10
1st dibs on the sunvisors, headlining joining strip and steering wheel. How much for all of them delivered mate?
Paul
im looking for drivers door lock pref with key if poss ?
and top half of a 2.5td airbox
can you pm me if you have one please ill prolly forget i posted this
andy
ps
sorry mate jumped the gun a bit should have read it properly feel free to ignore me till youv sorted your other bits out
soz
Hello. I'd like the plastics over the doors please. Can I also see teh B Pillar plastics there? If so I'd like those too.
What' sthe next step?:cool:
Ta
I'll have the fusebox cover :)
no problem, let me know if you want a price for postage or if your picking up T:
hi there 1st dibs on rear glass and step cover rear tailgate where are you based pleased
thanks pete
glass no problem dude but there is no step rear step cover- are you looking at the roof trim for the headlining?
i'm just outside caerphilly in south wales
Paul
will sort out a price for you mateT:
1st dibs on the gearstick cover please T:
no problem- got your pm will get a price for postageT:
Ta
b pillar trims not for sale mate- can take paypal, cheque or cash on collection its up to you, just let me know if you need a price for postageT:
I noticed the door pocket, is there a passenger door pocket?? if so I would be interested please.T:
no passenger door pocket mate
1st dibs on ignition shroud and 2nd dibs on B pillar plastics and passenger door pocket if you have them.
shroud no problem- the other bits are not available
Discussion Starter · #11 ·
Paul
delivery is £7 std parcel or £11 48hrs so totals would be £20 or £24
postage is £2.14 1st class or £1.85 2dn class totals of £5.14 or £4.85
postage is the same as above so totals would be £6.14 or £5.85
Ta
did not get price for these bot should be the same as some of the others at raound £7T:
sorry, i meant how much postage for the shocks!!
also i need a head lining strip too if you`ve still got it??
many thanks
hi mate thanks, i`ll have them please??
how about the roof lining strip??
let me know how to pay you and i`ll sort it ASAP.
cheers
1 - 20 of 22 Posts
