Hi
I have recently purchased a 1996 t4 westfalia and only just noticed the hazards do not work. The indicators work fine when the switch is in as soon as you push the switch to activate the hazards the indicators stop working and the hazards do not come on.
Any sugestions would be helpful or a wiring diagram. I assume that if the indicators work the relay should be ok and the fuse? The switch looks ok and have looked inside the switch all contacts look clean. If any body have any sugestions that would be very helpful.
The relay inserted is a westfalia one I assume for the towbar fitted??
