T5 1.9 84 120k
I think I have been unlucky and picked a problem van as already changed starter, engine mounts, drive shaft, anti roll bar links, front wrap around coolant pipe after just 7 months of ownership.
My latest issue is it is loosing coolant on long journeys and under load, while temp still staying @ 90, I have replaced coolant tank and cap and can now see coolant blowing out filler cap. I have had pressure test done and all fine. Yesterday had head gasket sniffer test done and it was quite clear after under a minute the colour changed so therefore gases getting into coolant system. How comprehensive is the test as I can't afford it not to be the solution. I am getting a quote as we speak so let you guys know...
