A bit of a heads up when you change the seals on the vacuum pump.
I changed the seals on the at the weekend and the job went well, apart from deciding to take off the oil pump to get better access and now the seal on the oil filter cooler has gone. Not a major job to change, but you think you've sorted the problem and you create a new one. For the sake of a few squid it's worth get the seals in ready.
The seals aren't expensive and are quite easy to replace.
