Can anyone tell me why my heater blower in the cab will only blow warm air even when temp knob is turned to cold.
there is a valve under the bonnet which is connected to your dials,on the bulkhead near the battery,it may be a broken cable or similar,get someone to move the dials and have a look under the bonnet to see if anything is happening,you can move it by hand if you need to for the time being
As above
On mine the rod was bent so when i turned the heater dial the rod just bent instead of moving the valve. straightened it up n its fine now:)
