1999 1.9TD. Whipped out the EGR pipe the other day and soon after noticed the heater temp dial would only rotate halfway I.e. from the cold position to around 12 o’clock position and therefore deliver no heat. Had a look under the bonnet at the Heater control valve.
Without ever seeing the valve other than in situ, am I right in thinking if the metal lever to which the cable connects is pointing toward the front of the van ie 2 o’clock, the valve is closed and will deliver cold air?
