Depends upon your electronics skills....
Chances are if they all are off, it's the regulator (small chip) that needs replacing, or even something as simple as a capacitor.
Other thing to check is, is there any 12v supply to the board? (Though may NOT be 12v, as in my van the leds dim with the rotary control for the rest of the dash....)
Supply probably comes from the main instrument panel.....with loads of connections that can fail over time....like my fuel gauge that gives up every summer when the sun hits the dash!
Take it out, good "tug" on the loom, plug it back in, and it's OK for another year.
Why do you need it anyway.....not rocket science to work out where your fingers are.
