Hi,I have the problem of when stationary the heater blows warm but when going its hot,i have a new genuine vw water pump,new Febi thermostat (which i tested before fitting) new dash heater controls but still no constant heat.I have been told that its most probably the Heater control valve,but where is it located? is it under the dash or in the engine bay?,i hope someone can help...
