hi folks
appreciate this is the T4 section but desperate times call for desperate measures!
on a T5 multivan where is the resistor pack / rheostat that selects the front windscreen demister fan speed?
usual fault - front screen demister fan only works when dial is on number 4, but cannot find the rheostat thingy itself to check it with a meter and replace it!
any suggestions of its location?
Never worked on a T5, or even sat in one for that matter.
The first place I'd look without fully knowing, would be around the ventilation fan cowling area. Alot of manufactures put them there. Sometimes mounted in air flow within the ducting to keep it cool.
Hope this helps a bit, but like I said in the 1st paragraph! I:
